Home > Maintenance & Modifications > dim light instrument panel |
Ihod Member Since: 07 Nov 2015 Location: Berkshire Posts: 165 |
If you want to retain the green backlit look, I just replaced mine with these (including all the hazard cluster) and they’re excellent:
https://www.ebay.co.uk/itm/281844489521 Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
12th Oct 2021 5:58am |
GRU54 Member Since: 03 Oct 2021 Location: Nashville Posts: 26 |
thanks I looked at them, If i only want that one for the instruments will he sell one only?
Thanks again! |
14th Oct 2021 1:24am |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 552 |
Hi Ian - did you find this an easy job or is it a pain/difficult to do? Are there any tutorials or instructions you could provide a link to as I really fancy this upgrade. Are you pleased with the results and do you feel it makes a difference and is worth doing? |
14th Oct 2021 4:42am |
The link was their eBay store but they are now online at www.embertonimperial.com and a quick email will get them sent out as singles.
Super easy job: 2 LEDs in the speedo 1 in each of the temp and fuel gauges 1 in the clock (different type of LED in a bulb holder ) All push fit - just be wary of the polarity so turn the ignition to position one and put the headlights on to check they light up and, if they don't, remove, rotate 180 degrees and put back. Even with my hands I managed to change them without disconnecting anything other than removing the four screws that secure the dash binnacle (but you can remove the lot by disconnecting the speedo cable and loom connectors). For the hazard block, undo the two visible screws on the front of the panel, lift out and remove the two ribbon connectors on the back. If it was like mine, a bit brittle and fragile but the bulb holders are twist out and bulbs are just a push fit (polarity applies with these LEDS, also) so just take your time. One point to note if you have trailer electrics, the LEDS draw little or no current so the trailer indicator may not light (or may stay lit very dim) so either leave the incandescent bulb in this fitting or replace the indicator relay with the variable type (for external LED bulbs). I'd say under an hour even if you take your time and the difference is night and day. I would post photos but just dropped the van off this morning for a soft-top conversion so will do that when its back. Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
14th Oct 2021 11:44am |
Thanks,
I just got the speedo bulb pulled out, it looks so small compared to the LED's in the ebay pics, (does that guy just have them so enlarged they look that much bigger?) its hard to understand how those will even fit back in that are you have to insert them into the guages...... thanks again |
14th Oct 2021 5:41pm |
Hopefully this helps:
Click image to enlarge Coin and tape measure for scale; from left to right: - LED for speedo, temp and fuel - the incandescent bulb it replaces - LED for hazard/warning light cluster - the incandescent bulb it replaces - LED for clock It’s fair to say the only one that looks remotely similar to it’s replacement is for the clock but the LEDs really do seat down into the holders - just make sure they are right in - and there is more than enough room within the gauge housings and warning light cluster for them to fit. I. Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
14th Oct 2021 5:55pm |
Yes that helps a lot, I want to get 3 of them seems the total is 43.32 ( 14.44 each) Paypal doesnt convert to U.S. dollar. Is this amount in british pound, euro, etc ? I really would like to know U.S. dollar what Iam paying per bulb. appreciate your help! Gary
15th Oct 2021 5:44am |
That's seems super expensive and you must be able to get them locally in the US (Amazon or Rovers North, maybe?).
What you are looking for is (I hope this is correct): The LED equivalent of a 194, 168, 501 or W5W wedge bulb (they should all be compatible) for the speedo, temp and fuel (you need 4) The LED equivalent of 286 wedge bulb a for the hazard/warning cluster (you need as many as there are light in use - not all of mine were wired in). And the LED equivalent of a 281 or BA7S 'peanut' bulb for the clock (you need 1). Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
15th Oct 2021 8:25am |
Click image to enlarge Right now Iam just trying to get the 3 bulbs for the speedo and to its left. Mine actually doesnt have a clock I wish it did but dont know where it would go. I have a blank spot to the left on the other pic. Not sure what goes there. Do you have a clock? or another guage in that spot? Could you send a pic? Ill get 3 pks of LEDs tomorrow from amazon Greens and white. Ill let you know if any of these work. Thanks Click image to enlarge |
16th Oct 2021 12:01am |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 |
Any reason these wouldn't fit a td5 dash?
27th Oct 2021 9:41pm |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 |
The clock fits into that space on the left of the other gauges. They do come up on ebay, not sure of he exact size. Jeff
28th Oct 2021 9:20am |
VDO gauge/clock.
52mm. The part number for the analogue clock is AMR3443. Ian MY1998 300Tdi 90 Hard Top (Now Soft Top) MY2015 110 XS SW - Sold MY2008 110 County USW - Sold MY1962 Series IIa Truck Cab - Sold MY1994 300Tdi 90 Hard Top - Sold MY2001 TD5 90 Truck Cab - Sold |
28th Oct 2021 9:22am |
Thanks so much
8th Nov 2021 7:38am |
