Home > Technical > Handbrake cure
austen
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Handbrake cure
My Puma developed the handbrake judder thing when approaching a stop. Slackening off the drum adjuster to the extent that the lever passed through 6 clicks before holding, made no difference. The trick is to set the adjuster on the cable, not the drum. Why the outer should lengthen, I don't know, but it does after a few thousand kms. Particularly when hot.
I shortened the outer by 5mm (turning the nuts so as to reduce the amount of thread visible) and then set the drum adjuster to factory specs ie. turn all the way in to dead tight then loosen one and a half turns. Actually I went out 2 turns but I now have a handbrake that holds at three clicks. The judder has gone completely.
Austen. Rover 12 1935
Rover 20 1940
Rover 100 1960
Defender TDC1 2008
FL2 TD4 2008
Post #6209 12th Jan 2009 1:40pm
Grockle
quick then mate,nice one. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #6210 12th Jan 2009 1:44pm
Grockle
should have said quick fix,oops 2.4 90 XS
Post #6223 12th Jan 2009 4:57pm
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
Austen
Thanks for the update, I took mine to the dealer and they replaced the drum, and reset the cable to near factory spec, although it was 4 clicks to engage, but the problem came back.
I have tried your solution and all seems good.
My only concern is that I am now out of thread / adjustment on the cable end and have had to back the actuator on the drum an extra quarter turn to get rid of the judder.
It is only on long runs, 400 miles, that the heat seems to build up enough, I wonder if the outer is expanding at a different rate to the inner cable and dragging it on.
Post #6369 17th Jan 2009 8:10pm
austen
Sticky
I have about 15mm of thread still visible on the cable adjuster. Sounds wrong that you are out of thread.
Rover 20 1940
Rover 100 1960
Defender TDC1 2008
FL2 TD4 2008
Post #6401 18th Jan 2009 11:11pm
Sticky
I will get the dealer to look at it.
Perhaps it is an out of spec part.
Thanks again
Post #6402 18th Jan 2009 11:23pm
