Home > For Sale & Wanted > [Sold] National Luna portable power pack |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 352 |
National Luna portable power pack with 11Ah leisure battery - £200
Pretty much 1 of these with the battery already installed https://www.nationalluna.com/product/porta...-hardware/ Appears to retail around £350 without the battery for the limited stockists in the UK (APB trading) The Portable Power Pack features fused accessory plugs, a polarised high-power plug and built-in battery monitor with low-battery and over-charge warnings. The built-in plugs can be used for low-power accessories such as refrigerators, pumps, compressors, lights and other 12-volt electronic devices. The high-current input-output can be used for higher power requirements such as invertors or battery chargers. The built-in split-charge isolator is fully automatic and does not require additional hardware in the application vehicle. Split-charge isolator built-in Integrated battery monitors Dual 2.4A USB charge ports NL5 Intelligent Charger port (charger available seperately) Fused accessory outputs Dimensions (L x W x H) : 500mm x 260mm x 300mm Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Keith Last edited by Keith5 on 4th Sep 2021 8:37pm. Edited 1 time in total |
11th Aug 2021 8:54pm |
chris h Member Since: 09 Nov 2009 Location: West Devon Posts: 47 |
PM sent.
REGARDS CHRIS 2009 110 SVX 60th Anniversary - Santorini Black |
22nd Aug 2021 11:06am |
Provisionally sold pending collection Keith
24th Aug 2021 2:11pm |
Chris Rogers Member Since: 28 Jun 2011 Location: Berkhamsted Posts: 26 |
Can I be the reserve?
Chris 2013 Defender 110 USW 2017 Range Rover Sport SVR 2019 Mercedes X Class V6 |
25th Aug 2021 5:48pm |
Sold Keith
3rd Sep 2021 11:39am |
