Home > My New Defender (L663) > [INSERT NAME HERE] |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 695 |
Looks great. Picking up my D300 on Sunday. I’ll try not to pull it apart for a small while, although might need to fit side steps and flaps! Just don’t like the idea of breaking plastic clips everywhere. 2008 Defender 110 XS SW - M57N2 / 6HP28X |
12th Jul 2021 1:47pm |
Ronin Member Since: 09 Aug 2012 Location: Kent Posts: 213 |
Thank you!
I hope everything goes to plan on Sunday Whilst I didn't fit my own, I got plenty up-close and personal with the rear flaps when removing the bumper to fit the recovery hoops. Happily, I think there's very little risk of breaking any clips when fitting those. The extended arches, on the other hand? I reckon I broke north of 20 b*****d clips when removing the standard arches Happily, the extended arches come with all the clips you need. Joel |
12th Jul 2021 2:57pm |
Tom_T Member Since: 08 Nov 2020 Location: Essex Posts: 87 |
Looks great! I love those wheels 😎. What is the offset comparison to the OEM wheels? I’m running 25mm spacers with standard 20” wheels and the same tyre as you are, but am wondering if the ET25 offset would put the wheel at the same position as I have, or if it would be slightly less and more akin to having a 20mm spacer, or perhaps even further to the outside of the wheel arch?
12th Jul 2021 6:34pm |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2260 |
I must be getting old All i think of when i see those great set of wheels is they'r going to be a to clean and polish! |
12th Jul 2021 6:42pm |
Thanks Tom. At ET25, these wheels stick out 16.5mm more than the standard wheels (assuming the same tyre width - I *think* the factory 20s are 8.5” wide), so nearer to a 20mm spacer than your current set-up. I had a set of 30mm spacers in the shed for a while, but thought that they pushed the fronts too far out. This combo is a fairly sensible compromise, which seems to keep most of the spray under the car. Joel |
12th Jul 2021 7:38pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1337 |
Very nice Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
12th Jul 2021 7:43pm |
It’s a fair point. Mind you, I haven’t felt the need to clean them just yet - what with all this beautiful weather we’ve been having As an aside, I’ve found that a spritz with neat Bilberry followed by a quick jet wash means that I can usually get away with non-contact wheel cleaning |
12th Jul 2021 7:45pm |
