Home > Puma (Tdci) > Wipers |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1196 |
Quite a common issue..
More likely a worn drive cable which runs from the motor across to both blades.. Or can be the actual wiper drives at the base of each wiper. You will need to take apart to know for sure. Not an expensive repair...just a little fiddly. Many write ups on here Clemmo Make today a little better than yesterday but not so good as tomorrow.... Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion Honda Benly CD200....Maroon ------------- Chausson 98.........7.5m of fun |
24th May 2021 5:57pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1729 |
Or in the motor drive itself, the circle falls off the pivot on the end of the crank arm and randomly changes park and sweep angles as the plastic bush moves....
Good luck! |
24th May 2021 6:09pm |
Howard Member Since: 06 Nov 2012 Location: Oxfordshire Posts: 41 |
Thank you for your replies, I replaced the cable last year because it had snapped. At the time they didn’t appear any free play in the spindles, and I stripped and re greased the gearbox on the motor. I think I will replace the motor and spindles .
24th May 2021 7:44pm |
