Home > Td5 > New to Defender.... Possible running issues |
davidblythe Member Since: 27 Apr 2019 Location: Cheam, Surrey Posts: 110 |
Hi
buy a nanocom, so useful, an egr delete, cat and middle box removal is a good starting point i havent gone for a tune as my 90 will do a gps 80mph on the motorway and this feels scary enough 1999 90 TD5 CSW 2006 110 TD5 HD Commercial |
10th May 2021 10:44pm |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 |
Thanks, will have a look at those, but they're a bit steeper than I was expecting, and not sure how often I will need one yet.
I presume you've done the EGr delete etc you mentioned. I'm sure 80 is pretty scary, but how noisy is it to get there? I'm wondering if I've got a vibration that I shouldn't have that is scaring me off at the 65 mark. |
10th May 2021 10:57pm |
pjm-84 Member Since: 12 Apr 2021 Location: Hampshire Posts: 647 |
I had an TD5 90XS a few years back and I had a stage 1 remap, which also removed the limiter. Would pull smoothly in 5 from 30mph up to a lot faster than standard. Perfectly stable at that speed, even on BFGs, but noisy
10th May 2021 11:02pm |
Beero Member Since: 05 Jan 2021 Location: Southampton Posts: 21 |
Quote "Due to this I'm suspecting the turbo actuator is a bit sticky perhaps."
I think this is the first thing you ought to check, easy enough to do, most fiddly bit can be getting the shield off. My 2005 TD5 pulls really well, only mod is EGR delete. |
10th May 2021 11:09pm |
Hmm.... this does sound like a likely culprit...
10th May 2021 11:41pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4966 |
You may want to check the maf and EGR, My 306 had a maf problem, and it wouldnt really move. Changed that all is well. The EGR was knackered on my 300 TDI, it just wasn't keen on moving up the box. Done away with that and it was like a different motor, So i would start with those two. Just in case that's causing some issues. also service it your self, never go by Full service given. Because my 300 TDi I had was very questionable with serving. The brakes been the major question! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
11th May 2021 12:08am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6051 |
Try unplugging the MAF sensor (It's on the big black air pipe right by the filter box), see if performance improves.
When they "die" they reduce performance a fair bit.... but when unplugged the ECU reverts to some factory settings that give some ooomf back. |
11th May 2021 6:50am |
nanocom i use whilst driving on any trip, it displays on 1 screen turbo boost, revs, voltage coolant temp, next screen maf, map flow etc etc there is no guesswork if you have a problem can get a hawkeye cheaper but doesnt show turbo boost 1999 90 TD5 CSW 2006 110 TD5 HD Commercial |
11th May 2021 7:03am |
