![]() | Home > Puma (Tdci) > noisekiller engine blanket highly recommeded |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
You're not the first to sing the praises of this this product: -
http://www.defender2.net/forum/topic4496.h...oisekiller http://www.defender2.net/forum/topic1183.h...oisekiller If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Could you post pics?
IID Pro MV License |
| rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297
just back from work. Will do in the morning
Click image to enlarge there you go what isn't visible in the photo is the flap that tucks down the back of the engine hence the L shape overall. You just have to bend it away from the exhaust manifold. You can also get an under bonnet kit but I think the blanket is better as it muffles the din at source |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472
I had a Td5 one which I shifted from vehicle to vehicle, it worked well. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
What is behind the plastic circle with Land Rover on it on the lefthand side of the engine? My 2008 Puma does not have this. 1982 88" 2.25 diesel
| Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180
Its the cover plate for the air con compressor drive belt and pulley |
That explains it-I do not have airconditioning. Thanks
Thank you mate
Thank you mate
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687
just wondering that this will do to the engine temp, esp in warm climates... --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
| pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
hmm expanding foam all the gaps should do the trick.....
Pom |
| nikojo Member Since: 06 Aug 2011 Location: Madrid Posts: 75 |
Do you have pictures of how you did the wheel wells??
Did you just stick on top from the inside?? |
sorry nikojo just noticed this but no pictures I'm afraid. I just plastered it on from the inside and put the carpet back on - job done and hidden !
