Home > Technical > 1999 defender cv joint spacer
Landy07
Australia
Hi Landy owners, I have a dilemma, I have a 1999 130 defender and recently replaced my front right cv and half shafts, after putting all back together and cleaning up I found "the spacer".
The original cv had exploded and all the bits were just scooped out with the grease, later found half of the original spacer so it was there originally.
Question is does anyone know if there are any dire consequences of not having this spacer in place?
Thanks
Post #894247 27th Mar 2021 2:18am
Dinnu
Which spacer are you referring to?
I know there are shims just between the drive member and the circlip on the CV joint shaft. That is to center the cv joint axis with the swivel axis. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #894259 27th Mar 2021 8:26am
Landy07
Australia
Hi Dinnu, definitely a spacer, looks like a ring, 8mm wide, maybe 1.5mm thick, slides over the spline before the CV goes on, sits on the inside end of the spline against the inner part of the CV race on the diff side of the CV.
In the attached image 17 is the spacer and 18 is the circlip.
Post #895014 30th Mar 2021 10:18pm
geobloke
Part number TYF000010.
It's a good sized spacer, I would say it is there to prevent the half shaft binding inside the CV joint. Also it will keep the half shaft in position in relation to the oil seal (571718).
I wouldn't run without it unless i really needed to get somewhere or get out of somewhere...
Post #895076 31st Mar 2021 12:01pm
Landy07
Australia
Thanks Geo for your response, unfortunately I'm unable to separate the inner drive shaft from the CV due to the circlip going beyond the end of the CV and opening up again, I feel the only solution now is to purchase a new CV again and replace.
Post #895819 4th Apr 2021 6:35am
Horneteer
United Kingdom 1986 Defender 90 200 Tdi SW Firenze Red
Hi Landy07
Have you tried holding the drive shaft vertically with the CV hanging down and giving the inner CV cage a good hit with a nylon mallet or block of wood and large hammer? That should knock the CV over the circlip as it's only a wire type clip and shouldn't damage the CV.
Tis worth a try.
Post #895922 4th Apr 2021 8:00pm
keef9t
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Once again, Britannica Restorations YouTube videos is your friend. Recent video shows exactly what Hornteer has just described.
Post #895926 4th Apr 2021 8:35pm
Landy07
Australia
Thanks, yes I've tried these techniques and also fabricated some jigs to Jack it apart with two hydraulic car jacks, still no good.
Post #895948 5th Apr 2021 4:32am
