Home > Td5 > loss of drive |
davidblythe Member Since: 27 Apr 2019 Location: Cheam, Surrey Posts: 110 |
10p TD5 90 have just lost drive in high and low box, however if diff lock is engaged, still have high and low box and the car drives
can select all the gears Nothing has fallen off that is immediately apparent, any ideas was just commenting the car is the best it has ever been 1999 90 TD5 CSW 2006 110 TD5 HD Commercial |
21st Nov 2020 4:33pm |
Could be a failure in a diff, a CV joint, a snapped half shaft or even one of the drive flanges. With one front wheel jacked up, turn the wheel by hand and see if you hear any grinding noises. Darren
21st Nov 2020 5:21pm |
problem is at the front end
front diff magnetic drain plug covered in swarf front wheels of the ground , when either wheel turned, nothing else rotates same with front propshaft strip down tomorrow looks like a failed front diff 1999 90 TD5 CSW 2006 110 TD5 HD Commercial |
21st Nov 2020 6:38pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16888 |
Oh dear, front diff. Unusual on a TD5 90 but that'll be no comfort. There are many upgrade options if you're so inclined, and cheaper than new genuine parts.
21st Nov 2020 7:10pm |
do tell 1999 90 TD5 CSW
21st Nov 2020 9:21pm |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 |
A common issue with front Rover diffs are the crown wheel bolts loosening and consequently shearing.
It happened to ours last year. Symptoms were some loud bangs in the transmission. Oil was as clean as could be, but the diff pan contained broken bolts and pieces of gear teeth. They didn't come out with the oil since the drain hole is not the lowest point . You might want to check with a small magnet. A while ago a bloke on another forum had all the crown wheel bolts broken, but miraculously the gears survived unscathed. Other possibility are broken differential gear pins. I installed an Ashcroft ATB as an upgrade. Plenty of opinions on the forum. j Antares Treadwell, a MY06 110 Td5 in Chawton White |
21st Nov 2020 9:37pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 899 |
Yup, happened to mine (2000MY 110) as well, just as described. I was convinced it was a transfer case issue. Simple fix in the end. One bolt One! 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
21st Nov 2020 10:12pm |
I too thought it was the transfer case first, so I ended up rebuilding that too. I even drove a couple of weeks with the front drive shaft only during which time nothing special happened, so the logical conclusion was that it was the TC's diff. I was almost disappointed when it turned to be OK.
J Antares Treadwell, a MY06 110 Td5 in Chawton White |
21st Nov 2020 11:35pm |
Ashcroft ATB is an obvious upgrade and cheaper than a genuine LR diff, and much stronger than the original 2-gear diff. |
22nd Nov 2020 12:03am |
