![]() | Home > Puma (Tdci) > Front Door Stays. Question |
Hi All,
The front doors stay fully open because as the Stay moves in the slide channel it pushes past a sprung steel rod that sits in a cutout on the channel. On mine I found, when adjusting the Stay Rod Bracket that the bolt holding the Rod bracket to the door frame was very loose. See picture. This Bolt is easily adjusted/tightened. BUT is there a second bolt, as there is on the rear door, hidden behind the dashboard end piece ![]() If there is, How do you tighten it without removing the dashboard ![]() ![]() My Land Rover is having the drive cable and spindle boxes changed on the windscreen wipers, under warranty, and I gather the dashboard has to be dismantled to do this so I would ask the Dealer to attend to these bolts while they are fixing the wipers if the dashboard has to be dismantled to get to these bolts. Thanks for any advice. ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
Had mine tightened a couple of times. As far as I know the dash was not removed but it was tightened by inserting a ring spanner. Have tried it myself but it is really awkward as it is impossible to get decent turns with it.I just live with the doorstay as it is. 1982 88" 2.25 diesel
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
you might be able to fit a ratchet ring spanner up there! BM52
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2498 ![]() ![]() ![]() |
You can also fit a small spacer (coin, washer) between the torsion bar and bracket to make it it firmer Puma 110" SW
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
Door stays? What you mean they actually keep the doors open? I thought mine didn't have any, except for stopping the door opening against the wing, so never questioned it.
Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
I'll get the dealer to do it when they sort out the Windscreen wipers. They are working at the moment.
![]() ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
