Home > Td5 > Replacement ABS pump? |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 757 |
I Believe that A disco 2 TD5 unit can be modified to fit, and are cheaper to get hold of.
Regards Chris |
29th Oct 2020 6:31pm |
Paullr90 Member Since: 06 Feb 2011 Location: Derby Posts: 93 |
29th Oct 2020 6:39pm |
There was a post on here somewhere about it not long ago- I have just been trying to find it!
Regards Chris |
29th Oct 2020 6:43pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6492 |
https://www.defender2.net/forum/topic73301...=abs+disco 1988 90 Td5 NAS soft top
2015 D90 XS SW |
29th Oct 2020 6:45pm |
29th Oct 2020 7:50pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2283 |
After the unit was repaired did you try out the ABS a few times?
Often it fails due to lack of use, the ABS rarely kicks in on a Defender driven on road. |
30th Oct 2020 7:53pm |
Just had the call from the garage I didn't want to hear. They've fitted a replacement pump, along with the new shuttle valve and again it initially solved the problem but within 10 minutes the ABS and TC light came on again.
Anyone any suggestions? All the wiring under the seat looks corrosion free I've changed the shuttle valve, and done the common wiring mod. Now I'm still back to having the warning lights on with no chance of passing an MOT. Any help much appreciated Paul. 2003 Td5 90XS 1970 Series 11A 2.25TD 2013 Freelander 2 HSE Lux (the wife's) |
18th Nov 2020 6:12pm |
Hi,
Has it been plugged in again since? Regards Chris |
18th Nov 2020 11:29pm |
19th Nov 2020 9:56am |
Hello,
It is possible to do a wiring bypass on the shuttle valve- its seems to be quite a common fix on D2s- if you do. google search it shows you how. Regards Chris |
19th Nov 2020 2:16pm |
vogue se Member Since: 24 Jan 2008 Location: Bocholt Posts: 111 |
I'm not sure about the Defender but the classic RR needed a replacement of a fast switching relay.
19th Nov 2020 5:54pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 583 |
Bypass is the easiest solution for shuttle valve switch problems - replacing the plastic holder with switches in not right solution, because the problem is in the connector in the main ABS modulator body. I made it on several D2s and few Defs. With not to big hands, it is possible withnout disconnecting the brake lines. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
20th Nov 2020 8:08am |
have you check wiring and connector to and from ABS pump and the control unit under driver seat
20th Nov 2020 10:32am |
