Home > In Car Electronics (L663) > Wireless CarPlay |
W84IT Member Since: 28 Sep 2020 Location: Indio, California Posts: 111 |
What you're describing is a software issue. You just need to update the software on the wireless device that you have. The GoPlayAuto device that I use for wireless CarPlay has been great. I was having the same issues that you described until I contacted the manufacturer and they told me to update the software. Since then, it has been working fine and I can't tell any difference from the wired connection. Ray
2020.5 Defender 110 P400HSE 2016.5 Range Rover HSE |
17th Jan 2021 3:11am |
GreenMonster Member Since: 30 Sep 2020 Location: Virginia Posts: 77 |
Thanks. I’ll give the update a shot. Doubt that will improve the audio quality, but I’ll see if it helps.
17th Jan 2021 5:11am |
VinSuz Member Since: 10 Nov 2020 Location: Pennsylvania Posts: 36 |
So still no word on wireless CarPlay in an OTA update? 2020 Defender 110 P400 HSE Santorini Black/Ebony
2019 Jaguar I Pace HSE 2022 Chevy Bolt 2LT |
9th Jul 2021 4:09am |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3265 |
The Velar has just been updated for 2021 and will receive a SOTA update to support wireless CarPlay, I assume the update will filter through the LR range.
From LR media site. “Wireless Apple CarPlay® and Android Auto™ is intended to be released as part of a wireless software update on all Range Rover Velar models expected later this year, at which point the features will also be available via a SOTA update for all Pivi and Pivi Pro equipped Range Rover Velar models.” 24MY 90 D250 HSE, Tasman Blue |
20th Aug 2021 10:22pm |
Received wirless CarPlay as part of an update done at the dealers.
If you have it you should have “wirless” listed in the connectivity menu, make sure this is on. With the phone unplugged I pressed the voice command (long press), then went into Bluetooth settings on my phone and reconnected the phone. It then came up on the pivi screen, can’t remember the wording but press yes. This was Apples instructions. 24MY 90 D250 HSE, Tasman Blue |
28th Oct 2021 6:13am |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1038 |
If you have wireless CP enabled, does it disable the wired CP?
I’m just thinking ahead, because I have put in a hardwired holder that charges my phone. I’d like to keep using it. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
28th Oct 2021 6:46am |
Brulz Member Since: 07 May 2021 Location: Brescia Posts: 23 |
have you check this post?
https://www.defender2.net/forum/topic80727.html |
28th Oct 2021 8:32am |
No idea, only played with it for a couple minutes before starting work. I imagine it won’t make any difference. 24MY 90 D250 HSE, Tasman Blue |
28th Oct 2021 11:52am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
The disco got this today, software no was v3
Defender update the day before didn’t get it, I wonder if it’s behind Mike |
2nd Nov 2021 11:38pm |
iOS 16 on its way, brings with it an updated CarPlay. Now works with interactive dash, apparently
Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
7th Jun 2022 11:07am |
Farmerben Member Since: 16 Jan 2017 Location: Herefordshire Posts: 604 |
The presentation looked slick and can see this being the "OS" fir an Apple Car (if it happens), but I doubt the hardware is there for it to be backward compatible with existing vehicles. https://instagram.com/bentheoandrews
7th Jun 2022 2:15pm |
