Home > Maintenance & Modifications > Drivers Seat Fuse Box - Switched live |
CallumB Member Since: 22 Sep 2018 Location: Norfolk Posts: 83 |
Oh holy rockster57! Well I'm glad you got the truck back but hope you or yours weren't hurt.
Yes, I'll have a look over the Haynes wiring diagrams to see if I can identify a suitable feed to splice into. Will let you know if I succeed (or go the gearbox route). Thanks for getting back to me so quick. |
23rd Oct 2020 5:57pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6510 |
If you have a 2.4 there are no ignition sources on that underseat fuse box. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
23rd Oct 2020 7:18pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
Cheers Martin.
23rd Oct 2020 8:02pm |
Thanks too Martin - didn't get round to investigating today so that saves me a lot of time!
24th Oct 2020 4:57pm |
Hello rockster57, just to let you know that I followed PaulMc instructions to the letter today. Big to Paul (again ). Heated seats now toasty and no fear of flattening my battery! Best of luck with yours. Only just got mine done thanks to the awful weather. |
31st Oct 2020 7:09pm |
Callum, embarrassingly my project is still on hold .
I’ve recently returned to work from furlough - which now could all change again next week! A bit more time at home would certainly help. At least I have gathered together all the components and wiring sundries required. Good to hear you have been productive. Nice work |
1st Nov 2020 12:31am |
Tonser Member Since: 08 May 2020 Location: Surrey Posts: 77 |
Hi all. I'm going to follow this plan too. Can anyone add a link to the relay used to trigger the ignition live please ?
Thanks Tony |
1st Nov 2020 7:27am |
^^^ Dont recall specifically where I obtained mine from but here’s one...
https://www.vehiclewiringproducts.co.uk/c-...ent-relays |
1st Nov 2020 9:43am |
Thanks Rockster
1st Nov 2020 10:30am |
I'm bracing myself here because I'm probably wrong, but that relay looks to be overkill. Based on the fuse and cable ratings on my exmoor trim heaters, I just popped down to Halfords and got a cheap 40A 4 pin relay for £8. Seems to run both seats on high with no issues. I'm sure that Durite relay is better quality than the one I bought though |
2nd Nov 2020 9:56am |
Callum, I wanted a supply (via a fuse box) for a variety of components ie 4 x roof mounted spots, twin work lights (all old school halogen), some side mounted scene lights, amateur radio equipment, fridge and camping power for example. Hence I opted for the 100A relay. I’m sure you’ve done the right thing for your own requirements
2nd Nov 2020 10:41am |
Blimey, for all that, yes you would! Sounds like a very nice overlander rockster57
2nd Nov 2020 11:18am |
MattyEssex Member Since: 23 Jul 2021 Location: Essex Posts: 77 |
Hi all this is exactly what I think I need to do.
I have Halo rings I need to be switched on my new Wipac Headlights. I also have Lazer Triple-R 750's that I need the position light to also be on the ignition switch and the main lights on the main beam / switched. Having read many many threads and the repeated advice is not to tap into something already present I am now of the opinion I need to add an additional fuse box with a new switched feed. Like others this is all new to me and whilst I could take it to a mechanic to do I want to do all the mods, fixes etc myself. I have a 2010 Puma 110 so presume I need to follow the instructions in this thread however I am not sure on the shopping list and where the best place for future additions the new fuse box should reside - USB, Roof lights etc all to be added at some point. I did buy the Lazer two light wiring harness for the 750's but not sure this is now needed. https://www.lazerlamps.com/two-lamp-wiring-kit-low-power.html Again any shopping lists and advise greatly appreciated. |
9th Nov 2021 8:22am |
