Home > Maintenance & Modifications > Receiver Hitch Choices |
Hello folks,
I've had Dixon Bate hitches on my last four Defenders but having sold my trailer and caravan in the last couple of years, hardly do any towing anymore. As a consequence, I fancy fitting a receiver hitch, partly for the novelty having never had one before, and partly as a strong recovery point whilst still retaining the ability to tow, should the need arise. As far as I can see, there are two options: Terrafirma and Safari Equip. Are there any pro's and con's for each or are they much of a muchness? The Terrafirma one seems to be more readily available, with the SE version not even featuring on their website, so I have little in the way of details about it (including the cost). Has anybody got any views or recommendations? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
6th Sep 2019 10:50am |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
I've been thinking about one too for similar reasons. I'll probably go Safari Equip because I have had other things of theirs and the quality seemed good. 2007 110 TDCi Station Wagon XS
6th Sep 2019 11:17am |
Yeah, I'm aware of the limitation, which I'm happy to live with. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
6th Sep 2019 11:28am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16894 |
I have front and rear SE receivers, completely happy with them, top gear!
Prior to 2012 N1 vehicles didn't require Type Approval on towing equipment, after 2012 technically they do. |
6th Sep 2019 11:37am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2233 |
I ordered mine from Flatdog. Website says Terrafirma but the item I received was/is Safari Equip. Got to be honest I didn't notice at the time, it was only afterwards I thought about it! I can confirm this after triple checking my email history!
https://www.flatdoguk.com/receiver-hitch-d...-2011~1571 Safari equip one is available from 4x4 overlander https://www.flatdoguk.com/receiver-hitch-d...-2011~1571 I can't comment on the terrafirma one but the SE one is nice. Pretty sure it's galvanised then powder coated. I say this as I managed to knock a little patch of powder coat off mine, but it never rusted. Plus SE galvanise and powder coat other products like tree sliders, which I also have, and the receiver is the same finish of slightly textured. What I like about the SE one is that it's box section rather than angle so looks tidier. Plus the box section width is the same width as the chassis rails so that the tie bars back to chassis are straight as opposed to cranked which means they perform better in tension > 110 XS Double Cab > Instagram @simonlanemind |
6th Sep 2019 12:00pm |
Ah, thanks for that. I didn't think of 4x4O. The price is very reasonable, too! Darren
6th Sep 2019 12:16pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 907 |
My SE receiver hitch Touched down this morning from Brendan at 4x4 overlander Fitting it at the weekend Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
6th Sep 2019 6:42pm |
I've just reserved mine for collection from Peterborough next weekend Darren
6th Sep 2019 9:26pm |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 397 |
I have the SE one and been very pleased. Will pull 12 tons on a flat hard surface (steam engine) very slowly. Not broken it yet. Slightly flaky coating but mine is s but abused.
If you ask SE, the will make up custom hitch inserts. For instance an upside down drop plate to put the nato hitch at xmember height for my sankey. Very pleased. |
6th Sep 2019 9:30pm |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 |
+1 for getting a receiver hitch.
definitely better than the standard boat anchor at the back. |
7th Sep 2019 12:23am |
Bill1919 Member Since: 04 Mar 2017 Location: Dorset Posts: 47 |
I looking to replace my standard LR tow hitch with a receiver hitch to improve the departure angle of my MY2015 110.
I understand the folding rear step needs to be removed for the Safari Equipment receiver hitch but what about the Terrafirma one. Has anyone fitted one of these and managed to keep the folding rear step. |
29th Jan 2020 11:35am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5424 |
From my understanding, you can road tow with these when fitted to a commercial vehicle. |
29th Jan 2020 9:08pm |
As Blackwolf mentioned above, the rules did change in 2012 so that get out doesn't apply to later vehicles. Darren
29th Jan 2020 9:44pm |
Andy RV Member Since: 26 Apr 2014 Location: Somewhere Posts: 62 |
Does anyone know if it’s possible to fit a NATO hitch onto the Terrafirma 2” receiver without it clashing against the lower two M16 bolts?
27th Oct 2020 9:57pm |
