Home > Tdi > Getting a garage to change cambelt 300tdi defender
KiwiNCFC
United Kingdom 1997 Defender 90 300 Tdi HT Arles Blue
Hello! I have owned my defender for around a year now and it needs it's cambelt renewing. I don't feel quite confident enough to change it myself this time around but maybe in 5 years time when im a bit more mechanically confident. I can change brakes /service and remove rads etc but I'm thinking of getting a local land rover indy to change the cambelt.
My defender is a 1997 300tdi and I know there is a modified cambelt kit for the later 300tdis but what other parts would you guys recommend on replacing whilst its in the garage?
Cambelt
Tensioner?
Aux belt?
Anything else? Would I have to ask for the modified cambelt kit or would any land rover indy know to fit it as standard? Also, what would a rough price on a cambelt change be just so I know if I am being ripped off or not.
Sorry for so many questions! Thanks in advance!
Post #788815 27th Aug 2019 11:21am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Water pump and p gasket too.
Also check water hoses for damage /degradation.
If you have the time to go slowly with the car not needed then it is a doable job for yourself.
Post #788822 27th Aug 2019 11:45am
KiwiNCFC
So the water pump and gasket can be replaced after the cambelt has been replaced?
Post #788839 27th Aug 2019 1:21pm
Balvaig
Depending on what work has been done to your vehicle in the past, the p gasket tends to leak, and the water pump may be at the end of its life. Whist you have bits stripped down to access the cam belt probably wise to replace these bits unless you know they are sound. Can be done afterwards if you wish.
Post #788874 27th Aug 2019 3:38pm
Jeebs
United Kingdom 1995 Defender 90 300 Tdi HT Barolo Black
I bought a kit from Bearmach, with belt, tensioners and the improved pulley, cost £70 I think.
It didn’t have the crankcase gasket, that cost me £14 from LR.
That’s what the belt looked like after around 75k....very near failure.
Post #788914 27th Aug 2019 6:30pm
yostumpy
Do you have a garage in mind. If not, might I suggest Island Landrovers in Essex. Martin Zammit does all the work on "Wallace" , my '98 300 tdi. Recent cambelt, rad, then head gasket/ skim and front discs and pads. Excellent chap, and knows his stuff, only does Landy's. 'Volvo XC 70, taking the rough with the smooth’
Post #788928 27th Aug 2019 7:26pm
Seawolf
United Kingdom 1995 Defender 90 300 Tdi PU Caledonian Blue
Other have given sound advice on the parts options.
I don't have the skills to do major work so I bought the parts online as it can be a lot cheaper and asked a local garage to fit them.
Post #789433 30th Aug 2019 7:25am
jst
That belt is worn but still a long way off failure. If that's the wear from wandering belt over 5 years or so, it needs doing but still quite a bit to go. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #789436 30th Aug 2019 7:46am
ickle
It never ceases to amaze me how some really worn out bits will go on and on if you’re stuck, but other well inspected and serviced items that look perfect can then suffer a complete failure a few weeks later.
Keith
Post #789437 30th Aug 2019 7:57am
yostumpy
mine was replaced, at a well over due 80k, but looked fine, no torn teeth, no cracking etc. but runs quieter now. 'Volvo XC 70, taking the rough with the smooth’
Post #789952 1st Sep 2019 9:04pm
NickMc
I buy my belts and critical parts from a local or reputable supplier. There are cheap fakes out there and low quality bearings. Don’t take a chance with timing belts Thumbs Up
300 Tdi belt is a pretty simple job, 200 Tdi can be a little worse with the long bolts in the case corroding. Just make sure you do the crank bolt up tight. Just run your belt round two revolutions and check your marks again.
Post #789986 1st Sep 2019 11:52pm
Oldowner
Have you got the revised injector pump mounting bracket on your engine? It’s needed if your belt is like that from running against the timing case. Fitting the improved pulley helps but really need to cure the problem with the bracket.
Post #790169 3rd Sep 2019 7:24am
