Home > Tdi > Crankshaft woes |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
As ever though, if you rebuild your own engine. You know what you have.
Whereas with another engine, apart from it being at least 21 years old, you have no idea what sort of knuckle dragging gorilla has worked on it. Similarly, if it is that good an engine, why isn't it in a vehicle? It is not a Defender, it is a One_Ten |
21st Jul 2019 5:05pm |
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 487 |
Yes that was a thought, however it is in a disco with a rotted out chassis so genuine reason for its being, I also know the owner and where he lives , so fingers crossed. 2015 RRS Autobiography SDV6
1994 Def 90 300tdi |
21st Jul 2019 5:15pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1571 |
pretty common fault on them, quick fix bush trick is brass key in and weld it up- remove brass key and bingo happens when the crank bolt isn't tight enough or works lose.
22nd Jul 2019 12:42am |
