Home > Maintenance & Modifications > volt meter and amp meter |
Wizard Sleeve Member Since: 02 May 2011 Location: Berkshire Posts: 25 |
Ive got this one:
http://www.nasamarine.com/proddetail.php?prod=BM1Compact Works lovely Click image to enlarge Click image to enlarge |
26th May 2011 12:55am |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
Went and picked one up today nice bit of kit have you got a winch on yours where did you put the shunt ???
Regard steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
26th May 2011 5:08pm |
Hi I run a split charging system for my audio and radio stuff vie got my defender. i have a winch but that is connected to my starter battery. The second battery is pulled in via a 300A BEP marine automatic relay. I run the shunt on the Neutral Leg between the two batteries. I have the second battery fused at 100A as the shunt is only Rated at 100A. But if you want to pull winch current through the meter then bigger shunts are available (Any companies work as long as they are the right A/mV output)
http://www.aacix.com/pdf/SR-current%20shunt%20resistor.pdf |
28th May 2011 11:48am |
Shutts Member Since: 10 Aug 2014 Location: Tiptree Posts: 52 |
Does any one know of a single monitor that can display the state of both batteries?
Andy |____000_ [l_|__\___\,___ l--___--_[O==O] ()_)' '()_)-----()_) 2005 D3 SE 1998 Disco 300tdi - slow play thing 1995 Defender 300tdi - Winching play thing Aprilia RSV 1000 - fast play thing Honda CR250 - noisy play thing Essex Land Rover Club member ------- Andy's Landy's - http://www.andys-landys.blogspot.com Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip |
18th Sep 2014 11:28am |
Simple solution perhaps would be to configure the wiring of the unit above through a simple relay and switch so you could switch between the two batteries to view the status of each in turn. If you go through life with your head in the sand....all people will see is an ar5e!!
18th Sep 2014 12:26pm |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
theres an ebay seller who does a 52mm dual digital voltage meter for about £30. Doesnt do amps though.
18th Sep 2014 8:39pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5743 |
If you have room I spotted this on the 'bay
http://www.ebay.co.uk/itm/DC-0-120V-0-50A-...27ec1544f4 not sure if any use? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
18th Sep 2014 8:45pm |
Thanks guys
A relay would work well and I could connect it via the ignition so it only shows when the key is turned. Also like the meter on ebay. I have plenty of room on the center dash to fit it. Andy |____000_ [l_|__\___\,___ l--___--_[O==O] ()_)' '()_)-----()_) 2005 D3 SE 1998 Disco 300tdi - slow play thing 1995 Defender 300tdi - Winching play thing Aprilia RSV 1000 - fast play thing Honda CR250 - noisy play thing Essex Land Rover Club member ------- Andy's Landy's - http://www.andys-landys.blogspot.com Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip |
19th Sep 2014 11:10am |
