Home > Technical > Steel wheel painting |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7866 |
I'd recommend speaking with Craig at Buzzweld, he does a range of excellent paints. I suspect a RCP primer would be good. James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
18th Oct 2018 7:54am |
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 783 |
Cheers just got in touch with them ๐
18th Oct 2018 10:30am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16812 |
What was their advice?
(Others may be considering the same question)! |
18th Oct 2018 11:02am |
To use there rust encapsulator as primer base coat which is handy as reading up on it itโs also good for chassis stuff. Will either go for aerosol or tinned and blow over with a spray gun. Not decided on top coat yet. Currently got wolf wheels in nato green satin so may go for the same on my mach 5โs as green wheels suit the truck ( ex mod) and break up the black of the wheels a bit
18th Oct 2018 11:16am |
Thank you!
I thought that "Rust Encapsulator" might feature in their reply. I have a set of wheels to paint for use on a Series 1, hence my interest in your question. |
18th Oct 2018 1:59pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 241 |
I had my series one wheels shot blasted. I picked them up then took them to the garage and covered them under a blanket. Two days later I went back to them and panicked as they were still bare metal and were showing the first signs of rust spots appearing!
I coated them all with zinga {from frost.co.uk} thinned down and sprayed through my cheap and nasty air compressor tool kit sprayer(Clarke) Now its primed and painted and im confident they will never rust again. 1953 80" 1987 mini city e 2011 90" |
18th Oct 2018 8:58pm |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
When I had my steel wheel blasted they were primed in a grey primer at the same time as part of the service.
My only quibble was that there were little bits of sand embedded in the seams which were a to get out. I've since gone over them which loads of thin coats of Rustoleum Hardhat White, which was advertised as gloss but is more of a satin finish which is a bit annoying. Oh well, apart from not being shiny they look lovely. |
19th Oct 2018 7:39pm |
