Home > Maintenance & Modifications > Removal of Mantec Raised Intake, help needed |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 |
Hello,
I previously had a Mantec Raised intake and removed it, I believe the hole behind the current side intake is from the previous RAI install. What is the part that needs to be replaced to retain the OEM setup? is it a Plenum? Click image to enlarge 2016 Defender 90 Adventure Edition |
17th Oct 2018 4:03pm |
Sky, not sure this is what you are after, but the genuine plastic outer grille has part number BTR6188.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
17th Oct 2018 4:28pm |
Hi I am not talking about the side intake cover or grille but whats behind the grille as I believe when installing the mantec raised intake a hole was needed for the ducting or replaced with a new plenum (guessing) 2016 Defender 90 Adventure Edition
17th Oct 2018 6:21pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6478 |
LR058109 - Puma 2.4 or 2.2 1988 90 Td5 NAS soft top
2015 D90 XS SW |
17th Oct 2018 6:26pm |
Thank you installed and working well. 2016 Defender 90 Adventure Edition
26th Oct 2018 11:44am |
