Home > In Car Electronics > LED Markers door handles etc.. |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 804 |
Somebody on here did a great write up on fitting puddle lights in the foot wells and I am pretty sure he fitted lights into the doors.
Unfortunately I’m not very good with the search function and am unable to find it. If you are better with that than I am you should be able to find something. 2002 110 td5 |
17th Oct 2018 9:19pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10420 |
^^^ your thinking of grafty99 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
17th Oct 2018 9:22pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2000 |
Some interior lighty up pictures here:
http://www.defender2.net/forum/topic30623-45.html |
17th Oct 2018 9:32pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
I wired mine to a usb slot that ive put inside the dash. Including an RF controller so the colour/brightness can be changed.
I if you only want green then you’ll just need a 5/12 volt supply. Depends exactly what you go for. My USB socket drops the 12v sown to 5v so the leds can operate correctly. You could earth the leds inside the door somewhere or run a pair of cables from your power source to each door, routed through the rubber gait or for the standard wiring you’ll end up with a nice clean finish. Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
17th Oct 2018 10:01pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4787 |
Think it may have been Roy5695 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
