Home > Technical > Td5 brake light bulb
Djcla
Any clues as to what I need to search for ie bulb type for the brake light bulb?
Post #734881 15th Oct 2018 7:39pm
Dieseljock
Scotland 2003 Defender 90 Td5 HT Zambezi Silver
R380 bulb. Twin filament stop and tail
Post #734940 15th Oct 2018 10:30pm
Djcla
Bulb swapped bu t it only works for main lights and not when I hit the brake. Is there only one way round to fit the bulbs? Not sure what's going on maybe electrical issue.
Post #735714 19th Oct 2018 4:06pm
Procta
check the contacts on the holder for corrosion, its happened to me with the indicators. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #735723 19th Oct 2018 4:49pm
rallysteve
Check the 3way connector at the back of the light. It should have three pins, i have seen several before which have lost a pin which is stuck in the plug.
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #735724 19th Oct 2018 4:54pm
Djcla
Cheers any good way to clean the contacts?
Post #735738 19th Oct 2018 5:51pm
