Home > For Sale & Wanted > [Wanted] Pre-Td5 blade fuse fusebox bracket |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6478 |
Before I cut and shut my glass fuse type to take the Tdi blade fuse holder, does anyone have a bracket?
Click image to enlarge PRC8072 or AMR3138 1988 90 Td5 NAS soft top 2015 D90 XS SW |
9th Oct 2018 11:12am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2196 |
No but i have got a spare glass fuse (MY84) one on the old wiring loom if you want a spare to cut up?
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
9th Oct 2018 12:00pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
I might have one, will have a look tomorrow if that’s ok?
9th Oct 2018 3:43pm |
Please Nick. Thanks for the offer Steve but I've no issue with cutting the one I've got - no way it's ever going back to glass fuses 1988 90 Td5 NAS soft top
2015 D90 XS SW |
9th Oct 2018 3:44pm |
I've got the actual fusebox and terminals already and I think a swap to the Tdi type will be easier than the Td5 or Puma one
Not that I'm shy of a wiring job 1988 90 Td5 NAS soft top 2015 D90 XS SW |
10th Oct 2018 10:49am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10358 |
Glass to blade fuse conversion is on my 'to-do' list, I got a full tdi loom and hacked it bits just for the fuse box
Are you using special connectors? Or cut/solder/heat shrink? Last edited by GREENI on 10th Oct 2018 3:40pm. Edited 1 time in total |
10th Oct 2018 3:39pm |
Animal 1988 90 Td5 NAS soft top
2015 D90 XS SW |
10th Oct 2018 3:40pm |
I bought this kit in February https://www.ebay.co.uk/itm/20-Way-Bulkhead...0873526036 February 2016 3waycomponents still do the terminals on their own: https://www.3waycomponents.co.uk/Terminals...l-51101980 Pricey way to do it though 1988 90 Td5 NAS soft top 2015 D90 XS SW |
10th Oct 2018 3:54pm |
Is this not for the Puma dashed-Td5-2.5TD conversion machine? I will look at the weekend I’m pretty sure I have at least one! Is the Td5 fuse box panel ok? I know I have one of those for sure.
10th Oct 2018 9:06pm |
Not going Puma dash in it, it's the testbed indeed but this is as much Puma as it's getting:
Click image to enlarge 1988 90 Td5 NAS soft top 2015 D90 XS SW |
11th Oct 2018 9:21am |
Did you get sorted Martin? Been mega busy and this slipped my mind I came across the type below tonight in Work and went “ahhh crap I forgot all about that” I know I have three Td5 bulkhead looms in storage- just have to find the right box
Click image to enlarge The Puma loom that the savages cut the the ECU plugs off Click image to enlarge Click image to enlarge |
18th Oct 2018 9:28pm |
Same as I've already got thanks though Nick
Why were the ECU plugs lopped off? 1988 90 Td5 NAS soft top 2015 D90 XS SW |
19th Oct 2018 11:05am |
Because it had the engine out and you know the easy way to remove the ECU then is to chop it off
I’ve set an alarm on my phone to remind me to look tomorrow afternoon wen I get home from work. |
19th Oct 2018 4:43pm |
20th Oct 2018 7:30pm |
