Home > Puma (Tdci) > Found a loose switch |
Hal Member Since: 04 Jun 2014 Location: Bedford Posts: 91 |
I believe it's the high-low detection switch electrical connector. Plugs into the other white connector hooked on the transfer box in your picture.
The other grey one at the top left had side (looks like it's all connected up ok) is the diff lock switch detection electrical connecton. See page 674 of the Puma 2.4 w/s manual (available on this site if you search for it). Check for yourself before you plug anything in! |
9th Oct 2018 2:23pm |
Tombte Member Since: 10 Apr 2011 Location: Across the field Posts: 37 |
Thanks Hal.
I'll study the manual. |
9th Oct 2018 4:26pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3615 |
Out of interest, it that the best way to refil transfer box oil I.e. from the top?
9th Oct 2018 7:33pm |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
Not unless you never have a cubby box fitted... Or you have lots of time to spare or already need to remove the seat box centre section.
Much quicker to use a garden pressure sprayer from underneath to be honest... Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
9th Oct 2018 8:20pm |
Cheers!
9th Oct 2018 8:37pm |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 172 |
Do your diff lock and handbrake lights work as its hard to see if they are connected or not? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
10th Oct 2018 5:30pm |
Both work well.
15th Oct 2018 9:10am |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2227 |
Could it be for the low range light? See here http://www.defender2.net/forum/topic50869.html
15th Oct 2018 10:14am |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 530 |
This is normal on a MY2009, see that old post http://www.defender2.net/forum/topic13589.html “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
-- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
15th Oct 2018 11:16am |
Thank you all for your replies.
Misterous switch... everything works, no plug to switch it, but sure it has or had it task... |
18th Oct 2018 8:43am |
