Home > Technical > Joining 1984 fuel tank to Puma gauge |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4388 |
Could you not fit a puma rear fuel tank and sender? You would have to adjust the mounts, but it should fit fine between the chassis rails.
8th Oct 2018 2:17pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6477 |
What year Puma instruments? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
8th Oct 2018 2:21pm |
V8Simon Member Since: 17 May 2016 Location: Prestatyn, Wales Posts: 137 |
2007 I think they are.
8th Oct 2018 2:23pm |
That's one option I'd not thought about but sounds fairly involved. I'm hoping there's a 'electronic' fix I can do |
8th Oct 2018 2:25pm |
Ok well how about this then;
https://sites.google.com/site/shannonpower...fuel-gauge |
8th Oct 2018 2:33pm |
Can you measure the "full" and "empty" resistance of your sender? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
8th Oct 2018 2:35pm |
Thanks for sharing |
8th Oct 2018 4:17pm |
I guess so using my multimeter. I'm thinking if I got the same info from a puma sender, I could follow the guide from Geobloke but with a bit more know how? |
8th Oct 2018 4:20pm |
2.4 Puma is the same as a Tdi and Td5. Haven't measured a V8 or petrol sender so can't advise without measurements 1988 90 Td5 NAS soft top
2015 D90 XS SW |
8th Oct 2018 4:26pm |
Learn something everyday |
8th Oct 2018 4:35pm |
So if I can fit a TDi sender in my tank which might be a little easier rather than try the TDCi one, it will be accurate on the gauge?? EBAY here I come.......... |
9th Oct 2018 11:40am |
In theory yes - my side tank sender (1988 TD) works the Puma gauges nicely, same as the rear tank sender (Td5).
However, get a multimeter on your existing one to see what's going on with the Ohms first. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
9th Oct 2018 11:42am |
