Home > In Car Electronics > 65 plate and headlight relay loom |
Mike_E Member Since: 13 Apr 2017 Location: Aberdeenshire Posts: 160 |
Afternoon,
With the dark season approaching I was going to get a relay kit for the headlights to boost the voltage... but I read some later cars do t need an aftermarket kit as LR modified the looms... true? If so does anyone know the cutoffs date when they improved things? Mine is a 65plate October 15 90 HT. cheers Mike |
8th Oct 2018 2:01pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
Mike...someone may contradict me...
I think they all benefit from a "loom"... as much as anything to protect the switch. There's a lot of people complain the headlight switch fails because "all" the current flows thru it. Most looms bring a Relay into the picture, reducing load on the original switchgear. I have LED headlights which draw less current, but I've still bought a LandResiger loom to "fix" the known problem (altho I have yet to install it but will soon!) of the "weak" standard loom... Hope that helps? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
8th Oct 2018 2:41pm |
Spot on. Thanks gents.
1 more piece for the shopping list!! |
8th Oct 2018 2:56pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19560 |
Highly recommend the Land Reiziger loom. Diesel$ Live$ Matter. ā½ļøš¢ļøšØāš§š§°āļø RED, WHITE & BOOST! š¬š§
8th Oct 2018 5:03pm |
Thanks. Read a few poor reviews of the "boomerang" loom...
8th Oct 2018 5:40pm |
sloderby1 Member Since: 08 Feb 2018 Location: Derby Posts: 20 |
Well they sort-of, the wiring for the very late models shows a headlight relay...but clearly this was an afterthought and bodged in where they could fit it. This relay is operated by the side/head lamp switch so this no-longer switches the full current, but the main headlamp current still flows through the dip/main beam switch. I've not seen the land reiziger loom, but I've seen the boomslang one & yes this could & should be better. I take issue with the single fuse in the latter for all headlamps. This is a serious safety concern as you will lose all headlights when this fuse blows - that is if the fuseholder doesn't melt first. |
8th Oct 2018 7:55pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16870 |
Really? There's been one, ignition-controlled, relay in the headlight circuit for years, provided so that the headlights only work with the ignition on, but I was unaware that there was ever another fitted from the factory. When did the second start being fitted?
8th Oct 2018 8:04pm |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
a bit of info about the relay... http://www.defender2.net/forum/post620643.html?
8th Oct 2018 8:49pm |
Indeed, I see your point there and something I've often thought about with any loom. However, I can confirm the Land Reiziger loom has two Relays both individually fused, the only thing shared is the single main primary power feed which is for ease of fitting which is a good thing. So, if Dipped failed main beam is present instead. And in my case I have LED light bars on another Relay and circuit which is triggered not via the Land Reiziger H4 connector but the factory H4 connector. So for talking sake, even if both Dipped and main on the Land Reiziger loom failed which would be uber unlikely I'd still have LED light bars instead. The only switch current running though on mine is the Dipped Relay current, main Relay current and LED light bar current. Under 1A max load though switch and with diode protection too to keep voltage spikes down. I'm glad that will not be a concern to me, as you say it would be incredibly dangerous fatal even in the wrong place at the wrong time. Diesel$ Live$ Matter. ā½ļøš¢ļøšØāš§š§°āļø RED, WHITE & BOOST! š¬š§ |
9th Oct 2018 12:08am |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
My lights and spots are wired in exactly the same way. Iām now going to tell everyone how I used my awesome electrical skills to give a triple redundant system. However, I never actually gave it a moments thought, just seemed like the simplest way 2007 110 TDCi Station Wagon XS
9th Oct 2018 6:36am |
Thank you, I'd entirely forgotten that thread even though I contributed to it! |
9th Oct 2018 8:50am |
