Home > Puma (Tdci) > Head light/side light switch replacement |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 |
Well the light switch on my 2008 110 has finally called it quits 6 week after fitting the BoomsLang headlight upgrade. S.H.M.B.O. went out this morning, returning to form me that the light switch is jammed on side lights, she managed with some force to switch them off. I know that it will need replacing but having undergone major surgery two weeks ago and having to sit on my hands for the next 8 weeks it is S.H.M.B.O. that will have to do it.
I can talk her through taking the cowl off under the steering wheel but are there any surprises with the switch and cable connector? I normally just pick up the phone and order what I need so is this the correct parthttps://www.paddockspares.com/prc3430g...lucas.html ? Any help would be appreciated. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
6th Oct 2018 4:44pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6479 |
That's the pre-Td5 one, you need
AMR6104 Well, AMR6104G for the Lucas part 1988 90 Td5 NAS soft top 2015 D90 XS SW |
6th Oct 2018 5:05pm |
Well I'm slowly turning S.H.M.B.O. into an apprentice.
25 minutes to change the switch with me uttering instructions like, "I don't know which screwdriver you choose", "have a look in the small red box for the security undoing things (torque head screws)" , keep the driver in line with the screws not at an angle" and "try the lights before you box it up" If I had been well enough I know where the screw driver would have been inserted. To be true she did well in finding the fault within two minutes of removing the cover, the retaining nut had come loose and worked its way up the thread jamming the lever of the switch, as she had the new one in her grasp she wanted to fit the new on so I let her get on with it, figuring out how to take the connector apart was a little test but she worked it out. Its all back together and she has inspected the old switch and cannot find anything wrong with it, which I can confirm no burnt out contacts or cables. Her next job is fitting aux driving lamp, switch and the wiring harness which should be fun. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
9th Oct 2018 3:51pm |
