Home > Puma (Tdci) > Removing tow bracket |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6461 |
Dig out the fitting instructions and start at the end 1988 90 Td5 NAS soft top
2015 D90 XS SW |
5th Oct 2018 8:18pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1546 |
Yep all the bolts that it goes into on a Tdci are captive on a Tdci. Soak them in something for a few days before you attempt it, if you snap one it can be a real swearing match On some drop plates you need a thinner wall socket to get the main bolts out as they’re close to the edges.
Three along the bottom. Click image to enlarge Click image to enlarge |
5th Oct 2018 8:40pm |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 205 |
Thanks, does that include the ones that go up from beneath, the ones that hold the angle iron on?
Sorry, just re-read your post and you already explained! Not sure why you would need a thinner socket all are in an accessible place as far as I can see! |
5th Oct 2018 8:49pm |
If you have a Dixon bate style drop hitch the bolt head is very close to the uprights on the slider.
5th Oct 2018 9:25pm |
Oh, I see, I don’t, so no problem! Thanks again.
5th Oct 2018 9:35pm |
