Home > Technical > New Coolant Gaue TD5 Defender |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4395 |
I gave in and cut the pipework to fit the gauge sensor. I believe there is a modified coolant to head flange that has a position for the standard sensor and a second auxiliary one allowing the ECU and a separate gauge to work.
I will see if I can find it again. Incidentally not had a problem with the inter-hose sensor since fitting. |
26th Sep 2018 1:40pm |
Here you go - https://goreproducts.com/products/td5-coolant-housing
The only reason I didn’t go this route is that I couldn’t get the part in time so went standard outlet elbow and hose insert. |
26th Sep 2018 2:18pm |
