Home > Maintenance & Modifications > Heater controls too bright.
Likeomg
Somehow not too sure how the bulb that lights the heater controls blinds me now when im driving...
I wedged a bit of tape in there just for the time being but does anybody have an actual fix?
Other than remove the bulb....
hard to photo but
Post #728188 9th Sep 2018 9:56pm
Likeomg
I do have a single din fold out with lots of connections on the back... but it had been fine for 2+ years...
Post #728189 9th Sep 2018 9:57pm
Either the holder has come adrift or the bulb is failing and has become a lot brighter. If the latter, sort it asap since it will also have become a lot hotter and will melt the housing, probably rendering one or more slider inoperable. You will then be faced with an absurdly huge bill for a replacement heater control panel. Ask me how I know this....
Post #728191 9th Sep 2018 10:14pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
that does look very much like the bulb has fallen out of the holder and is now lighting up EVERYTHING behind the slider
Definitely needs investigation sooner rather than later Shocked 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320
Post #728197 9th Sep 2018 10:56pm
zsd-puma
the slider has a bit of thin plastic attached to it's stem I think. This slides back and forth with the slider to block the hole up. Looks like it's become misaligned or damaged to me. A bit of black plastic cut from a ready meal pot or similar would replace it.
Post #728205 10th Sep 2018 12:49am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Pretty common fault on circa 2011 models. Mine failed and melted the slider in the off position. Fortunately I had the extended warranty which covered the repair. I think the new panel was around £400 - ouch!
Post #728227 10th Sep 2018 8:15am
