Home > Tdi > 300tdi EGR ECU |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 |
There won't be any faults if you remove it as the system only reads other information to operate the EGR valve.
Can remove the modulator from the bulkhead, unplug the injection pump sensor, the vacuum hose needs sealing up and the ECU can be unplugged. |
10th Sep 2018 8:09am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 4908 |
Yeah just blank the full lot off under the bonnet, with the kit. Then just unplug the EGR ECU and bin the full lot. Mine was really sluggish with it on, as soon as i binned it, it made the motor a lot more lively Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
12th Sep 2018 5:06am |
shayes Member Since: 29 May 2016 Location: Devon Posts: 153 |
Same as above by Procta. Engine runs a lot better now.
Simon |
12th Sep 2018 8:19am |
