Home > Maintenance & Modifications > Castor Corrected Swivel Balls - Anyone used them? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2591 |
my Puma has had a tendency to pull left since new, which was somewhat solved by JLR replacing the entire front axle.
But having swapped out my BFGs for Goodyears, the truck has started wandering again. Wheel alignment shows a 3 deg castor on the left and 4 on the right, so would using these help correct the wandering? Where does one buy these? The wheel alignment chap reckons a 6mm spacer on the left front radius arm should push the left wheel forward enough to cure the issue, but I'd rather get a better solution if possible. thanks -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
23rd Aug 2018 8:28am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
my 130 is only a 130 on the passenger side its a 131 on the drivers I don't think I have ever had a Defender that's had the same wheel base both sides. Go and measure your truck and see what differences there are 130's have feeling's as well you know
23rd Aug 2018 10:39am |
these are the wheel alignment figures:
Click image to enlarge -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
24th Aug 2018 10:44am |
