Home > Td5 > Air Vent hinge pin removal |
shayes Member Since: 29 May 2016 Location: Devon Posts: 153 |
Hi,
When I swapped the pins for s/s ones I found that the original pins were really rusty, not allowing the vents to move freely. I applied copious amounts of freeing up lubricants then got a pair of bull nose pliers on the ends and wiggled them about to free them up. I then pulled them out towards the washer jet (there was not enough room going the other way. They didn't have anything stopping them coming out, like latchs etc. It will just be years of rubbish/rust seizing the pins into the vent pin holders. Got into some strange positions up on a step ladder, at the side of the rover, to enable the removal though!!. Good luck. Cheers, Simon |
20th Aug 2018 11:46am |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 249 |
Yeah, I took off the NS Windscreen mount ( sanded and lacquered it) to get enough room to try and drift out the pin.
You do get some funny looks from passers by when you're spread eagled across the bonnet fighting with stuff though o.k. I'll get some mole grips onto the end of the pin and see if I can pull it out. Given that the damn thing ain't moving at the moment, don't need to worry about damaging the threads thx A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
20th Aug 2018 1:20pm |
