Home > Puma (Tdci) > Serpentine belt Tensioner |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 980 |
Do you need some sort of tool to take off the tension when changing the belt?
Merlin |
13th Aug 2018 8:50pm |
Just uses a 1/2" square drive, so a breaker bar, or ratchet, there is a sticky at the top of this section....
http://www.defender2.net/forum/topic47382.html |
13th Aug 2018 11:43pm |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 |
3/8" square drive ... Solved the bowel problem, working on the consonants... |
16th Aug 2018 12:38am |
