Home > Technical > Truck failed us in France |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
I have located the immobiliser, it seems to be a YWC500640
https://www.lrdirect.com/YWC500640-supplie...rover.html It has a single orange wire not connected to anything coming off one off the connectors, maybe a function that isn't used on the Puma? I notice it says 433Mhz on it, so can it be interfered with by another source of 433Mhz ? Also does anyone know if the key fobs talk to the immobiliser once the alarm is disarmed ? ie if the key fob is faulty or low batt, can it interfere with the starting of the truck ? JD 2008 TDCi 2.4 XS CSW |
11th Aug 2018 11:18am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19535 |
The fob does have to be in the vicinity of the ignition when starting and the alarm and immobiliser has to be disarmed before starting.
Have you tried just pressing unlock before starting? Turning over, sometimes starting and then shutting down is often the immobiliser if armed and starting is attempted. There should also be no armed dash light flashing either when you go to start. (Red.) I'm sure someone will be along shortly that knows more the electronic intricacies to it than I do. Checking the plug to the rear of the IPAC. (Instrument cluster.) is securecis also an issue that can occasionally occur. Also that Relays under drivers seat are secure. Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§ |
11th Aug 2018 11:48am |
Hi Steve
yeh tried all that but thanks, it never fires, just exactly 4 turns of the starter I am guessing, then cutout, no firing. JD 2008 TDCi 2.4 XS CSW |
11th Aug 2018 3:21pm |
I think the orange unconnected wire is the ariel. Ray
11th Aug 2018 4:04pm |
v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 437 |
I had a similar problem. Go to start, turn over a few times then dead....but locking and unlocking always cured it.
I plugged my nanocom in and turned off the passive immobilisation and that cured it |
11th Aug 2018 4:08pm |
With regards to the orange wire, yes it is indeed the aerial for the device, A guy I spoke to who repaires these units said the bare wire at the end should be insulated so it canβt touch anything and degrade the reception of the unit, I have now taped over the bare end just in case........mine was bare exposed wire
FYI JD 2008 TDCi 2.4 XS CSW |
15th Aug 2018 5:34pm |
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 616 |
Interesting.... It sounds to me like RF interference or a duff exciter ring. I get a similar issue now I have a X-eng steering lock fitted to mine. If I don't hold the fob in the right place I get either nothing, a turn over for a few times and stop, or sometimes it even fires then dies. V8 90...WIP
15th Aug 2018 5:47pm |
What talks to what on the unit, what is the aerial on the 10AS unit picking up, and why have the exiter ring around the ignition as well as, surely the aerial can Pic up both signals?
15th Aug 2018 5:55pm |
The exciter ring round the steering is for the immobiliser: It talks to the fob bit of my key set up (a 2013 car with a separate black fob and key).
The AS10 aerial picks up the signal when you press the button on the fob. V8 90...WIP |
15th Aug 2018 6:01pm |
Ok thanks.....makes sense.......would a low batt in the key fob cause an immobiliser confusion, the new batteries I put into both remotes a few months ago seem to measure only 1.6 volts instead of 3, well one certainly does, could 1 low batt remote in the car cause issues with the good fob OOI ?
15th Aug 2018 6:15pm |
I don't know the answer to that - sorry. V8 90...WIP
15th Aug 2018 6:22pm |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 242 |
have you tried / do you have the eka (emergency key access code)? 1953 80"
1987 mini city e 2011 90" |
15th Aug 2018 9:28pm |
