Home > Maintenance & Modifications > ARB bushes |
The drop links are tapered on the inside so the bushes just pop out and in, really simple to do, you only need to undo one bolt you donβt need to take the link right off the car. Ray
10th Aug 2018 3:49pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19568 |
Ah I see, for some reason I had it in my head that they were press fitted much like the rear damper upper mount.
Then I saw they were two part bushes and I wondered how easy that'd be to do underneath but they do t seem to bad then which is a good thing. The rear NS seems a little skew wiff on the bush which happened after I hit quite a big pothole hidden in water last year or whenever it was. That's good I can leave them in situ then and just Dinitrol and replace the two part bushes, much faster job. Should it be of any use to anyone the drop link bushes P/N: Bush - 552819 - Genuine. Fits front and rear 2007 > Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§ |
10th Aug 2018 4:40pm |
I did my rear drop link and anti roll bar bushes the other week in about 30 mins without rushing at all. Ray
10th Aug 2018 5:53pm |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
Mine were a bit of a fiddle but not too bad, including changing after work and putting my tools away it was an hour's job for me.
Getting them in wasn't really easy, I think I used a G clamp to help. It wasn't difficult though. Same part as a Series 3 shock absorber bush I think? |
10th Aug 2018 6:36pm |
It's the compressing them in concentric before tightening that I was wondering would be a fiddle.
This is why I was wondering if doing in on the bench might be easier. I've emailed Dan @ Duckworth parts so will go for there. Diesel$ Live$ Matter. β½οΈπ’οΈπ¨βπ§π§°βοΈ RED, WHITE & BOOST! π¬π§ |
10th Aug 2018 9:35pm |
