Home > Puma (Tdci) > Welding on a TDCi what do I disconnect? |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Just pull the negative (earth) lead from the battery. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered. |
9th Aug 2018 9:09am |
Following the handbook instructions to disarm the BBUS first, if you have one fitted. Darren
9th Aug 2018 11:28am |
PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 123 |
I don't think Ozzie spec Defenders had that.
9th Aug 2018 2:30pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19568 |
As well as the negative, take the positive off too and check all switches are off.
You should then be good to go. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
9th Aug 2018 3:13pm |
Why? ^^ 80" 80" 86" 88" 90"
9th Aug 2018 3:39pm |
Just completely isolates everything that way.
Depends on what type of welding in question as well. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
9th Aug 2018 3:46pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 572 |
Key for safe welding is good ground connection close to the welding point and on the welded part. This will minimize current leakage through rest of the car. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
9th Aug 2018 3:55pm |
