Home > Maintenance & Modifications > Sagging Door Seal |
Black Tack. All you need to know is in below thread.👍
Eric http://www.defender2.net/forum/topic33097....black+tack You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
2nd Aug 2018 2:35pm |
Here is the link to what I bought. Works perfectly, as good as the old dum dum.
Eric https://m.ebay.co.uk/itm/Zinge-Industries-...+tack.TRS0 You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
2nd Aug 2018 2:38pm |
Try pulling it off again and squashing the u channel part of it tighter together, then push it back on again.
2nd Aug 2018 3:09pm |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 445 |
+1 above!
I had the same issue, took it off, squeezed it tightly together and pushed it on and its never moved since - brilliant! |
2nd Aug 2018 7:19pm |
Sammyboy Member Since: 28 Feb 2017 Location: Hampshire Posts: 121 |
Thanks guys, great advice. Discovery 4 HSE
Defender 2.2 110 USW XS Ford Kuga AWD Discovery 3 Range Rover P38 Discovery - 300 TDI Discovery - 200TDI |
2nd Aug 2018 7:40pm |
