Home > Puma (Tdci) > Theft/Immobiliser alarm movement detecter disable for pets |
lock it with key
2nd Aug 2018 11:25am |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
If only I could......at some point before I acquired the vehicle, the ignition was replaces, I only have keys that fit the ignition...... 2008 TDCi 2.4 XS CSW
2nd Aug 2018 11:29am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16874 |
Unplug the wire from the internal sensor if you can't lock with the key.
Some people say that simply putting some insulating tape over the sensor itself works, but I haven't tried this. |
2nd Aug 2018 11:33am |
2nd Aug 2018 11:35am |
Is there just the one sensor?
JD 2008 TDCi 2.4 XS CSW |
2nd Aug 2018 11:40am |
Yes, just one sensor. It's held in place with a spring clip and so just pulls out of its' mounting point. Darren
2nd Aug 2018 12:41pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2495 |
The advantage of taping over the sensor as opposed to using the key to lock the vehicle is that you still retain perimeter protection on the bonnet and doors. Defender 90XS SW
2nd Aug 2018 12:52pm |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 |
2nd Aug 2018 1:49pm |
Thanks everyone, I'll tape over them I think
2nd Aug 2018 2:08pm |
On most cars if you have central locking, then locking with the key still arms the alarm without arming the volumetric sensor. However I don't thing this is the case with the Defender. |
2nd Aug 2018 3:16pm |
If you're going via the Tunnel there's no real need to lock the car, its not as anyone can escape. |
2nd Aug 2018 3:18pm |
Its the Normandie Express from Portsmouth
4th Aug 2018 10:59am |
JellyBean Member Since: 02 Mar 2015 Location: Suffolk Posts: 142 |
Where are the sensors....?
5th Aug 2018 7:12am |
when sitting in the drivers seat its above your right shoulder.
5th Aug 2018 11:12am |
