Home > Td5 > gaskets required for a transfer case swap |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 906 |
Nope no gaskets on the T-box to G-box join. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
25th Jul 2018 5:29pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6036 |
None, just a bead of silicone around the joint. well around the shaft....
be careful you don't damage the oil seal as the t/box is offered up into position.... hence why the sealant around the shaft |
25th Jul 2018 5:36pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5738 |
Cheers all. 1999 Defender TD5 110
25th Jul 2018 6:21pm |
