Home > Technical > 110 puma abs fault 4014 |
highlandlandyman Member Since: 05 Jun 2013 Location: tain highland Posts: 1 |
ok folks got a weird one here 08 puma 110 abs fault showing on hawkeye pro 4014 pump system 3 failure , this is where thinks get interesting .clear the fault code , drive car all works as it should , switch it off fault reappeares as soon as you restart the landy ,how ever if you switch landy off while still rolling forward and restart the fault resets and both abs and TC operate as normal any one had similar issues landyman
23rd Jul 2018 2:33pm |
