![]() | Home > Puma (Tdci) > Front window dropped |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Nice one Mick, put some stud lock on them
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Well It's a Land Rover
This thing happens to me at the beginning (Only 2,000 km old) at the vacations, so I dismantle the door with the help of the dealer at the other side of the phone and found the same problem that you. In my case the bolt were loosen from factory. Check also the other window... Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 ![]() ![]() ![]() |
Same happend to my last puma, was in the Alps at the time.
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Will check the other side sometime thing is the door cards are so s**t and i have had them off once when the door handles came loose as well
G4sweep Member Since: 24 Sep 2010 Location: Paderborn Posts: 182 ![]() ![]() ![]() |
My front left did the same a while back, easy fix as has been said, door card off and put bolts back in
![]() ![]() 2.2 110 XS SW ---------------------------- Gone; 08 D3 XS BN55 WPV G4 4.4V8 D3. O7 G4 Mongolian Recce 110 USW |
There was a SSM for this issue, SSM39031 referred to the bolts coming loose and the use of loctite to rectify.
