Home > Tdi > Cracked cylinder head? |
trickster5000 Member Since: 12 Dec 2015 Location: East Yorkshire Posts: 489 |
Hi,
To give background: Bought a 300tdi for 50 quid last summer with absolutely no history/info. Chucked it in my 90 and it's been running flawlessly for the last yr covering approx 5k miles but pretty much all less than 30 mins and no motorway. Yesterday, I went laning in the Dales which involved a decent stretch of motorway driving to get there. On the motorway on the way home the temp went into the red and it spat out all its coolant through the expansion cap. We weren't far off home so just chucked some more water in and gently drove home at no more than 50 ish. By the time we got home it had yet again spat out all the coolant. I took the head off today and found this: Click image to enlarge Click image to enlarge Click image to enlarge Cylinders 2 & 3 look to have cracks from the glow plugs and cylinder 4 looks to have a crack between the injector and one of the valves. Additionally there are marks from the water jackets to the cylinders: Click image to enlarge Do these pictures look characteristic of cracked 300 heads? Is a cracked head effectively scrap metal? Where's the best/cheapest place to get a recon or brand new head? Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
8th Jul 2018 3:14pm |
I've now had a better chance to have a look at the gasket and the block and it looks like the HG failed around the triangular-ish water jacket between cyl 2 and 3. This would explain the coolant pressurisation.
Additionally the small coolant hose that goes into the thermostat housing was completely blocked with cruddy deposits which means exhaust gases in the system from the HG failure wouldn't bleed properly causing air locks and overheating. Before I spend £300+ on a new head I'm going to put a new gasket set on and just see if that fixes the coolant pressure problems for now and worry about the suspected head cracks when the symptoms arise. Matt. '89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html |
8th Jul 2018 10:26pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4937 |
I wouldn't bother doing that, id just get the lot sorted out. You don't want to be pulling it to bits again. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
17th Jul 2018 6:12am |
