Home > Maintenance & Modifications > Transfer case with centre ATB |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2871 |
Grafty /George has one
27th Jun 2018 10:37am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6260 |
guilty.
27th Jun 2018 10:40am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5725 |
You have one as well Caterham?
Calling grafty/George (same person?) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
27th Jun 2018 10:47am |
PM replied, I'll pop it up here too
In my experience it makes a big difference. More stability at all times, especially during heavy braking which surprised me. I didn't think about the positive effect of fitting it for slowing down but it does reduce the tendency for the back end to step out when braking at maximum effort. It makes a big difference to traction out of sharper bends (such as off wet roundabouts). Before, you would get lots of front inner wheel spin causing understeer. Now, with power sent to the back, there is less overall wheel spin and understeer. This makes for a more stable cornering experience. Off road difflock is required much less. I did a days offroading on Salisbury Plain in the thick wet mud. My defender is on 285 section road tyres and I didn't get stuck once. I think I may have engaged diff lock once. My defender doesn't have traction control but I'm sure with such a defender the difference off road would be even greater. Once it is fitted, after a few hundred miles, you completely forget it's there. No extra noise or scrubbing on full lock. In fact I would say it reduces some backlash. All in all a great upgrade. I'm sure with front and rear diffs the conversion would be formidable 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
28th Jun 2018 2:40pm |
Cheers Grafty.
For me the 110 is a daily drive and then at weekends, towing rally cars in forests which are often churned up or slippy after 160 or so cars have been through or race circuits (which have some wet grass which is boggy - don't ask me how I know ) Certainly food or ATB for thought. Currently out of stock at Aschroft's 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
28th Jun 2018 2:54pm |
I'll be honest in that I'm not sure.
It was suggested it would help with reducing slack in the transmission - in hindsight I'm not sure how but perhaps it does. All I can say is that I've got no adverse comments to add and certainly it does drive lovely now. Would I buy another ...... yes in so much that I know it drives well without it and wouldn't want to be without it to wish I'd got it ie if I were having another transfer box rebuild. Sorry I can't be much more help. |
28th Jun 2018 6:54pm |
Well.. 30 miles in after having the new TC fitted with the centre ATB.....There is certainly less backlash, not sure how much is due to the new TC or ATB, or a bit of both.
So far no rough stuff/wet roads but on road manners appear the same. I have a few forest events coming up soon so that will be a good test. The change between a 1.2 ratio and 1.4 ratio is power is back, a little louder but to be expected. Anyone want to buy a 1.2 ratio box? See advert in for sale section 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
9th Aug 2018 7:42am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7664 |
For towing in those conditions, axle lockers would be most useful, esp the front on climbs Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
9th Aug 2018 8:14am |
Lockers would be nice and would certainly help. 1999 Defender TD5 110
9th Aug 2018 10:15am |
