Home > Technical > 300TDi Not Starting |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1968 |
How bad is the fuse box? Pictures are always good. I had a G4 TD5 that had been on both trips, including across the salt flats. The fuse box on that was a bit on the crusty side. An hour or so cleaning up and it was fine.
22nd Jun 2018 1:12pm |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 941 |
Sounds very similar to a problem I had a few months back. I was recommended to install immobiliser bypass which cured the problem completely. Was easy to install as well just drill out the rivets, pry the box open and plug the bypass in. 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold 1985 Land Rover 110 ex mod project Tithonus ~ Sold |
24th Jun 2018 11:25pm |
Roosterrs Member Since: 19 Feb 2016 Location: Northants Posts: 48 |
It’s been a while but my 300 TDi has been starting fine ever since we had the hot weather this summer. So I am wondering if it’s damp related. Any one else had a starting issue disappear since we had the hot weather?
25th Sep 2018 11:32pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
Your problem is most likely the fuse box corrosion as you’ve discovered.
29th Sep 2018 4:30pm |
