Home > Maintenance & Modifications > Low mileage. Is it worth changing fuel & air filters? |
If it spends a lot of time sitting about then changing the fuel filter won't hurt, incase there has been any bacteria in the 'stale' fuel.
Air filters you can visually check for condition - in fact the transits used to have a red/green indicator on the filter housing, you just changed it when it popped up. |
17th Jun 2018 3:45pm |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1285 |
Good point ZSD on the fuel filter.
I've ordered a Mahle filter off Fleebay this afternoon for the bargain price of £10.50. At that price it isn't even worth the debate. When I did the airbox mod a few months ago, the air cleaner looked like new anyway and at the time I gave the fins a good blast with the air line. So I won't bother changing it right now. |
17th Jun 2018 8:06pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
I service my 110 at every 6k miles or 1 year which ever is sooner.
My service consists of every 6k/1 year - Engine oil + filters Air filter Grease anything with a nipple Plus a checking everything else 12k/2years - Above + Diffs, TX box, gearbox, swivel grease (i tend to use proper EP90) Fuel filter I try to plan to service when i think ill hit 6k but sometimes it ends up being much lower as either a long trip coming up or knowing I wont have the time. Most recent service was done at 4900ish miles as off to france next week for some offroading so wanted everything fresh as possible. No harm in changing service parts often. Generally quite cheap ive found (then again i did bulk buy genuine oil filters for a steal!) I also tend to think more frequent oil changes are better than using a pricey oil for a longer period. Instagram @defender_ventures Empire Tuning - Agent |
17th Jun 2018 9:13pm |
