Home > Td5 > Injectors |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
My TD5 once again seems to have air in the fuel system which is making it splutter when starting from cold. Strangely it seemed since i last did the injector seals in March and is only since changing the fuel filter a few weeks ago. No signs of a leak though!
The injector that is in No.3 cylinder has a fault with the rings on the washer sealing face of the injector. Previously the washer has held for 12-18 months before needing replacement. This time is seems to have potentially given up early. Therefore, i think i need to change the no.3 injector. Am i better to try and source a set of injectors from an unknown donor vehicle so all injectors have done a similar mileage? Can they be refurbished at all? I know i will need to track someone down with nanocom to reprogram them whether i change one or 5. Photos of a good injector seal removed (note clear indentation from good injector) Click image to enlarge And bad one from faulty injector on cyl.3 (incomplete indentation ring): Click image to enlarge Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
17th Jun 2018 12:06pm |
The injectors can be refurbed but I found it cost nearly as much as buying new ones from britcar (which are genuine ones) so I ended up just getting a new set from them. Ray
17th Jun 2018 4:10pm |
Cheers, so the question really then is: Can i swap out just my one damaged injector and leave the 4 remaining ones in which have done ~125k?
Sadly I cant afford the £1250 for a full new set! Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
18th Jun 2018 4:08pm |
Cheers. The issue is with the actual metal around the base of the injector. Normally they have two concentric raised rings which crush into the washer. My faulty one has a large section of the inner ring totally missing and a small fault in the outer ring. Not sure how this has happened but has been like it since the first time i did the seals. Almost looks like porosity in the material although i doubt this would have been missed by Delphi's QA from new.
The mating face of the injector and the recess in the head were spotless when i reinstalled them previously. Thanks for the suggestion though! Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
18th Jun 2018 5:44pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 539 |
if you do wire wheel them do not wire wheel the tip as this can damage the holes then it will need new nozzles.
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt |
19th Jun 2018 12:48pm |
Any other thoughts on me replacing just 1 injector (thus 4 will have done 125k) before i pull the trigger on a new one?
Thanks in advance, Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
16th Jul 2018 5:40pm |
