Home > Maintenance & Modifications > Another seat related question. |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 985 |
New seats don't have removable bases. I can still push the seat all the way back and get some access to the seat boxes, but more would be better.
Is there any way to remove whatever stops the seat going back any further? I assume there's a block or something in the seat rails. I have mud rails, so nothing in the way. |
14th Jun 2018 5:51pm |
I'm surprised no one has come up with some hinged rails so you can tip the seat back for access.
14th Jun 2018 7:34pm |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 |
I put in a ctek comfort charging point, that at least helps getting to the battery to charge it, without having to pop the seats should I need it. TBH, I don’t have any reason to go under there anyway, if you need to jump the battery, you can get to both terminals, or put in an Anderson plug
15th Jun 2018 9:12am |
