Home > Maintenance & Modifications > Seat belt buckle length
AMBxx
New Corbeau seats in. Only downside is that with the mud seat rails raising the seat, it's now awkward to buckle the seat belt.
I've found extenders like these: https://seatbeltextenders.ecrater.co.uk/p/...der-type-a which would do the job, but I'd prefer to be able to just change the buckle to one with a longer arm, raising the whole buckle.
Is there such a thing?
Post #712346 14th Jun 2018 5:49pm
zsd-puma
you could probably put a spacer between the bottom of the seat belt stalk and the seat box with longer bolts. Obviously there would be considerations towards making sure it was of appropriate strength.
Post #712365 14th Jun 2018 7:33pm
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Re: Seat belt buckle length
Have same set up, all OK with standard seat belt hook up.. low base or high base seats?
Post #712402 14th Jun 2018 10:26pm
AMBxx
High base
Post #712418 15th Jun 2018 6:22am
2010Blackdefender90
That’s the problem, I tried high base, couldn’t get to the belt to plug it in, the seat risers might have to come out to lower them, if you keep the standard belt attachment.
Post #712426 15th Jun 2018 9:07am
