Home > Td5 > ABS sensor leccy failure |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 573 |
If the problem is there immediately after ignition swithing, without moving the car or axle, than probably death sensor or broken wire, or bad contact in connector, of not connected.
Broken wire is possible to find and repair. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
10th Jun 2018 4:10pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
Ill have a dig around. Did go for a drive and yhe lights went off then quickly returned so backs up a broken wire idea! Instagram @defender_ventures
Empire Tuning - Agent |
10th Jun 2018 4:22pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2199 |
Presume the sensor is fully seated into the top of the swivel pin? Also i assume you have checked CV endfloat and shimmed up?
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
10th Jun 2018 5:34pm |
Replaced with the same shims that came off it. Fuly seated Instagram @defender_ventures
10th Jun 2018 6:15pm |
