Home > Puma (Tdci) > New vcv (Denso) learning wit BAS rrc? |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 832 |
Have you tried contacting Pete at BAS via his website?
https://bellautoservices.co.uk/ He was very helpful when I had a similar problem. In my case recon injectors were the cause of the problem. |
9th Jun 2018 5:11pm |
toetankh Member Since: 05 Aug 2015 Location: Papendrecht Posts: 22 |
Haven't done that yet.. Will send a note to him as well.
Just want to emphasize that I'm not suspecting the BAS device to be the cause of the problem, has been working fine in every aspect. |
9th Jun 2018 5:15pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Have you got it up to temperature? Sometimes they are a pain to do a relearn on. If you keep getting the fail to relearn I wouldn't worry to much about it. It will relearn itself over time anyway.
9th Jun 2018 5:24pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
I’ve never done it on the BAS machine, but on autologic the car has to be to temperature like has been said.
9th Jun 2018 6:17pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2588 |
Sven, I've done this procedure a couple of times, always successful.
At which point does it fail? Right at the end? Or somewhere in the middle? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
9th Jun 2018 6:21pm |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 427 |
Just out of interest, I don't suppose you have anything none standard attached to the alarm/immobiliser system?
9th Jun 2018 9:06pm |
Thanks for the suggestions!
Engine was at correct temperature (the BAS tool checks this) Seems to fail at the end. I can then abort or restart (which then ends with again the same message.) Hope its nog injector related (nothing changed) Alarm is standard (bbus moved bowever....) |
9th Jun 2018 10:35pm |
Mine did this. Went through fine once I replaced the PRV on the back end of the fuel rail with a genuine one. The pattern one from Transit parts just wouldn't pass the learn.
It may even be that your current PRV has gone pop and needs replacing anyway. |
9th Jun 2018 11:17pm |
Yep aftermarket sensors can be the problem too as Mr Zsd says.
9th Jun 2018 11:48pm |
Pete gave me a tip to try and drive the car a bit longer and then try again.
If that doesn't work, I can also replace the PRV, they don't seem to be that expensive. Will keep you posted |
11th Jun 2018 9:29am |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
I Had the same problem, I must have tried to learn it 7-8 times and it would always fail at the end.
I took Petes advice and went for a long drive as well (40 mins round trip to town) and it seemed to work. |
12th Jun 2018 7:35am |
Johan H Member Since: 12 Oct 2017 Location: Helsingfors Posts: 36 |
I had the same problem with failing learn process, called Bellautoservices. Pete told me the ambient temp also has to be above 15 degrees.
I'm waiting for spring... |
18th Feb 2020 1:37pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16870 |
I no longer bother to do a pump relearn after a VCV change, and just let it sort itself out.
18th Feb 2020 3:55pm |
keef9t Member Since: 13 Mar 2016 Location: manchester Posts: 168 |
I didn't bother with a re-learn either. It worked fine
18th Feb 2020 6:01pm |
